1. Login to disable the Ads!
Spark Plug Socket
Discussion in 'N54' started by Cheezy, Dec 9, 2016.
  1. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    Just incase you ever run into an emergency and can't find your sparkplug socket, AutoZone carries them for $6.99 so you don't have to overnight a $19.99 socket from Amazon!
    Part number: 72-376
    • Like Like x 1
    • Informative Informative x 1
    • List
  2. Euro venom
    Euro venom Specialist Girl Club
    95
    Tualatin, or
    I'm doing my spark plugs tomorrow, thank you for the tip. :)
  3. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    Yep, they're not magnetic but the gasket or whatever you want to call it on the inside is super stiff, great hold.
  4. Euro venom
    95
    Tualatin, or
    I'm a woman, I can handle the stiffness. Lol
  5. R.G.
    R.G. Lieutenant
    564
    Henderson, NV
    Ride:
    E92 N54, F02 N54
    Definitely get a magnetic one...
  6. Bigdaddyaaron
    Bigdaddyaaron Corporal
    137
    USA
    Tell that to Ellen DeGeneres
  7. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    Well I used the AutoZone socket today, no problems. Don't understand why everyone recommends magnetic over gasket type. Anyway here's some pics of what your plugs look like when you have bad injectors. PhotoGrid_1481568592396.png PhotoGrid_1481568751952.png
  8. ATL-IS-N54
    ATL-IS-N54 Sergeant
    260
    ATL ga
    Just did mine today... Got the tool
    From bavauto for 7$... Had my Indy code in/ program my car to take the AGM battery tho
  9. ATL-IS-N54
    ATL-IS-N54 Sergeant
    260
    ATL ga
    What kind of bad injectors ? Like
    Leaking ? Or ?
  10. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    Idk I think just leaking. Car still runs with no codes, cold starts have a little bit of a slow crank, some insane throttle closures at wot .this is the suspect. Just wanted to have all the information before I take it to the shop so I checked plugs today and they're ugly. I'll be sure to get back with you with how bad they were when I get them replaced. I can't wait to beat my car again :(
  11. ATL-IS-N54
    ATL-IS-N54 Sergeant
    260
    ATL ga
    I had BAD throttle closures more noticeable in gears 3-6 mostly 3-4, after a new set of index 12s, mine were like 8, and a new coil, it's 99.9 % adapted and cured... I did the plugs today, and then had Indy do battery, so idk what all adaptations were reset, but my trip clock was reset..., anyway, new injectors covered by BMWs extended fuel system warranty / recall, about 500 miles ago, a carbon blast, and a new coil on 5, and over the next 500 miles got better and better, still had a slight idle stumble so I did the plugs and battery today as it was warning me of low charge too... Runs like a champ... The carbon blast and injectors was worlds better tho
  12. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    Nice, I just did my battery not too long ago. My injectors are also 8s. Going to get 12s. Replaced a coil today because it had a bunch of condensation on it and I have spares so why not. OFHG is getting done too so new oil and coolant then hopefully I'll be set to do some pulls. Need to find a local guy to do walnut blasting.
  13. ATL-IS-N54
    ATL-IS-N54 Sergeant
    260
    ATL ga
    Few questions... How many miles and what year car? And where do u source coils? I was going to order a set of 6 Bosch from FCPeuro unless someone tells me otherwise... Just to have around when they go... So far only #5 is new
  14. Cheezy
    Cheezy Lieutenant
    536
    Toledo Ohio
    08 e92 335xi idk the mileage exactly but I think it's nearing or low into 88k. I found Bosch 00044 on Amazon for about $21 each so I bought them. That was a while back tho, and the one I replaced was a Delphi or delco or whatever brand. It was in the car in cyl6 when I bought it. Could've replaced it sooner but it didn't give me any problems. I always keep a couple spare in my trunk
  15. Euro venom
    95
    Tualatin, or
    I'm sure she uses vibrators lol
  16. Bigdaddyaaron
    137
    USA
    Nah she gets off through dancing lol
  17. R.G.
    R.G. Lieutenant
    564
    Henderson, NV
    Ride:
    E92 N54, F02 N54
    I was constantly having to use a magnet grabber to pull the plugs :/
  18. N54 BR0
    N54 BR0 New Member
    Yup... We ditch our OEM ones at the dealer for magnetic BMS ones lol.
Loading...
